Quantcast
Free Oak!!
A
Anonymous
Guest
Hi
I've got an Oak tree stump that I want to remove.
I was enquiring about a chainsaw today & the chap asked me how big it was. When I told him, he said he thought that some people would be willing to come & take it away for the wood??? (Is this true???).
It's just over 6 foot high & about 30 inch diametre. I live in Merseyside.
Going free to anyone who wants it :wink:
MWM
DaveL
19 Oct 2002
Sudbury, Suffolk
Oh yes its true. :D
The only problem for me is your too far away. :x
A
Anonymous
Guest
That's a pity. Ah well, maybe someone local will want it.
God knows how they'll get it on a vehicle though. I'd have thought it would be well over a tonne.
MWM
trevtheturner
26 Feb 2003
Herefordshire, UK.
Hi MWM,
I would deal with it with a chain saw, by slabbing it vertically, in situ, to ground level, say in 3" slabs. Then, with another pair of hands to keep control of the slabs, cut through at the bottom, removing each slab as it comes free. Needs a bit of care, but I have done this successfully in the past. Using a chainsaw, there is a fair bit of waste but still plenty of valuable wood left.
The slabs are then manageable and can be resawn, planed, thicknessed, etc., as required after drying.
Cheers,
Trev.
devonwoody
11 Apr 2004
Paignton Devon
My thoughts were also to chain it down. Someone is then sure to come along and remove it for you free of charge :)
Pete L
24 Aug 2005
Salisbury, Wiltshire
Many years ago I was faced with a similar problem, although the stump concerned was from a yew tree, and was about 3 feet high, and about the same diameter. I found no simple or easy answer, but I dug around the stump using a maddox axe (a bit like a pick axe, but with an axe blade on one half of the head, and a heavy duty 'hoe-like' blade on the other). By digging a moat around the tree I was able to cut through the roots as they were exposed, and then rock the stump back and forth until it worked free. If the hole is really deep the only way to extract the stump is to use planks to wedge in the hole around the stump levering it out bit by bit (rather like creating an inverted wig-wam type of framework of the planks). Cutting the stump with a chain-saw may reduce the size and allow bits to be taken away by people who want the wood, but you are still left with the residue of the stump.
cheers, Pete L :wink:
devonwoody
11 Apr 2004
Paignton Devon
What did the farmers do 200 years ago when they had ten of them in a field.
It has often worried me that one. :)
jasonB
26 Nov 2004
Surrey
They also had much smaller fields and probably left the trees in the hedge rows. :D
Jason
Gill
3 Sep 2003
Lincs
Another ancient technique was to cut the trunk at ground level, then cut a cross into the top of the stump. Over time, rain would penetrate into the trunk through the cut cross and make it rot from within.
Gill
Bean
12 Jan 2004
scouting about
A carefully placed explosive charge works well :wink:
As does a landrover moving at moderatly high speed with a good strong chain................actually this one is a bit dodgy, so i'll leave it there
Bean
trevtheturner
26 Feb 2003
Herefordshire, UK.
Yep. To coin a phrase, I know where you're coming from, Bean. I'll leave it there...........
Cheers,
Trev.
Jorden
11 Jan 2005
Leicestershire
I tried that one once Bean, series one landrover, a stout rope attached to the tow hook at one end and a large bush at the other. Accelerated away, rope stretched a little, bush let go of the ground and flew at the landrover. Net result, one broken back window, a cab full of rope and bush and me, wondering where I get these silly ideas from!
Dennis
Taffy Turner
24 May 2004
The Land of My Fathers
Cheers,
Trev.
Yep - me to I'm afraid.... :oops: :oops: :oops:
Gary
