Frank Klausz Dovetail Blade
Mrs C
3 Jan 2016
United kingdom
I have just been watching the Frank Klausz 3 minute dovetails. He cuts the whole dovetail with just a saw using a blade where the first section has no teeth enabling the Saw to be turned and a horizontal cut to be made.
Anyone know if these blades are still made?
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
I haven't spotted that but I assume he'd just have filed some teeth off.
Cheers W2S
MikeG.
24 Aug 2008
Essex/ Suffolk border
That's not what he has. It is a frame saw in which he has the ends of the blade turned 90 degrees to each other, so that there is a twist along the length of the blade. He pushes the vertical section of the blade down the kerf he cut with his other saw, then pushes hard and the twist starts the cut with the horiztonal part of the blade. It's a party trick, and not worth bothering with.
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
Aaaaah that makes sense. I sometimes do that by accident with my coping saw! :roll:
Benchwayze
10 Mar 2007
West Muddylands
He's a bit of an expert with the frame-saw for dovetails. There's something in his eye that tells you he's taking the Mick; in the nicest way of course!
I just like his way of cutting dovetails for 'utilitarian' jobs, but it isn't as easy as he makes it seem!
John (hammer) (For Bishoping my DT's)
