DaveL
Thomas,
You where interested in how I had prepared the waney edge boards, as promised here is a set of picture of the process.
The small board that I am going to work with.
I have a very crude sled made from a piece of chip board with some toggle clamps.
I clamp the board on so where I want to cut is parallel to the edge of the sled. One edge of the sled slides against the fence on the saw, guiding the board.
Then set the fence on the saw, my saw is a B&Q one just like yours. I use safety glasses and ear defenders, even with the dust collector running and the guard down the dust can surprise you.
That gets me one straight edge on the board.
As this board is more than 10" wide, I will rip the other edge so it will go through my planner/thicknesser.
Then I flattern one side on the planner.
Followed by squaring on edge.
I now have to convert the machine to thicknessing mode.
One cut and it just cutting the high spot off.
As I am not machining this to use straight away I stop now most of the board is flat. When I cut it to size I will thickness it to the required size but this will now rest until required.
The other reason for stopping the dust bag is full :?
I hope that makes the process clear.
