I've upgraded grinders to a Tormek to allow me to grind P/T blades. As a result I have my Draper whetstone grinder for sale. I'm looking for between £30 - £50. It's hardly been used. More pictures at bottom of post.....
click on image for larger view
Due to the weight, I won't send this by courier, it's delivery or pickup only. I'll consider delivery in the Sussex/south Surrey area. Personal Message me with an offer if you are interesed, otherwise, I'll put it in Friday ad.
Adam
Here's a bit from the Draper website...
The draper on-line shop has it at £170 - although I'm sure I've seen it for sale recently in the £120 region, I paid £100 for it, about a year or two ago. The instruction manual can be found here (click on link)
http://www.drapertools.com/draper/external/31235ins.pdf
Adam
Designed for the workshop to hone and grind hand and garden tools. With a whetstone honing wheel, dry white grinding wheel, eye protection shield, spark deflectors, wheel guards and adjustable tool rests. Uses white dry grinding wheel especially suitable for high speed steel tooling. Fitted with a BS approved non-rewireable 3 pin moulded plug and cable.
Whetstone wheel diameter ... 200mm
Whetstone wheel bore ... 80mm
Dry white stone wheel dia. ... 125mm
Dry white stone wheel bore ... 12.7mm
Speeds:
- Whetstone wheel ... 320rpm
- Dry white stone wheel ... 2850rpm
Motor ... 350W - 230V AC
Machine dimensions ... 460 x 320 x 300mm
Nett/gross weight ... 10/11kg
