Flying Dutchman Blades
Alexam":elf6ive9 said:
Where is the easiest place to get FD blades now please? Do they all come from abroad or is there a UK outlet?
Malcolm
I think someone mentioned here on forum that Hegner sell them under different name?
Can anyone confirm that?
It is said that FD blades are made by Niqua, but if you want FD blades then Mikes workshop is the place, though now owned and operated by Wooden Teddy Bear. Postage is quick and reasonable, but if you place a large order you could get stung for import duties and tax.
http://mikesworkshop.com/
happy scrolling
Steve
Alexam":ust2wx5q said:
Where is the easiest place to get FD blades now please? Do they all come from abroad or is there a UK outlet? Malcolm
Having bought a couple of bad batches of FD blades I personally wouldn't touch 'em again. However, if you wanted to try a few different Niqua blades Malcolm, send me your address (via a PM) and I'll send you a few to try. The Niqua factory is just up the road from me so I thought I'd give them a go. They seem pretty good on first use and appear to be just as good as Olson and a lot cheaper.
I have a German contact on ebay.de who sells them in dozen batches with free shipping after the first dozen (for German customers). For UK customers it is €5.10 for first dozen and €0.10 for each dozen after that. Still MUCH cheaper than the USA ;-)
If you want to try a few out give me a shout.
Barry
Thanks for the replies Guys, all usefull info. I have just been trying a few Pegasus and FD blades and narrowed my choice to a couple of Pegasus and a couple of FD's. I did add my little review and show the square of ply I used for the test on the end of my 'HOW MANY' blades question.( how-many-t96543.html )
If the Niqua are in fact the same blades, then it would be good to try #3 and #5 reverse or skip blades if you have a couple to send Barry. That's very kind of you and I will PM my address and let you have feedback once I have tried them to compare.
I am fairly new to scrolling and although I have done 'bits', I really want to get going with the new scrollsaw and try out sopme Intarsia and see if I can make the grade of some of the guys on this forum if possible.
Malcolm
Don't quote me on this, but though the FD-UR blades, which seem to be the favourites amongst FD blade users, are made by Niqua, I think they are only available from Mike's Workshop/Wooden Teddy Bear, not from Niqua or Hegner
Regarding the issue that some say that FD blades are made by Niqua, My experience is that for many years I have used Niqua blades from Hobbies UK and they have worked just fine, after reading good reviews in this forum about the FD blades I decided to try some out but so far I have not had much luck with them, they keep breaking long before they wear out!
If it is true that Niqua make the FD blades I can only assume they are made to a lower standard or I had a bad batch because I never have problems with the Niqua branded ones breaking.
Sorry Martin but in fact Niqua DO make the equivalent of the FD-UR blades. Its called the Niqua Top Cut and has every third tooth reversed.
Niqua's description says "First class saw blade for delicately cutting of difficult work pieces; suitable for wood and plastic; hardened, every 3rd tooth is countered; 130 mm long."
No.........W x H x L.........Teeth per cm
2/0 ......0.21 x 0.68 ...............15
1 .........0.30 x 0.77................15
3 .........0.34 x 0.90................13
5 .........0.38 x 0.93................13
7 .........0.42 x 1.10................10
I'll pop a couple in a bag for you to try Malcolm ;-)
Incidentally, in Germany, fretwork blades are known as 'Laubsägeblätter' . . . . rolls off the tongue easily huh?
Barry
    249.3 KB
No need to be sorry, Barry, I am always happy to be corrected. Do they have the kink in the blade to show which is the top, that the FD-UR blades have? Comes in handy if yer peepers aren't too good. :)
Precisely the reason I keep a jewellers loupe with my blades. 8)
The Niqua Top cut do not have the kink at the top end of the blade.
happy scrolling
Steve
Hi, All I have been using F D blades for about a year after I had tried quite a few other brands and found they where the best, i got mine on Ebay got three doz for a good price and free p&p, I got a new prooxon at Christmas and they sent me some off there own blades which I find quite good. hope this helps, John.
