Flooring question?
Rob Cheetham
11 Sep 2018
chaddesden derby
I have decided to do a 22mm chipboard subfloor and then get a heavy duty lino to go on top. Below the chipboard will be some extra dpm then 50mm celotex with a vapour barrier before the chipboard.
My question is this. Do I have to put down say 50mm joists to secure the chipboard flooring too or will it sit firm and still by just gluing all the joins together making one big sheet. Or is there some sort of adhesive I could use mayby to stick it to the celotex? There are no joists at the moment as I have just sat the frame on a course of bricks and a 100mm concrete pad.
Im just parnoid that when the lino is stuck down I will feel movement from the subfloor when walking on it if its not secured down.
Any advice would be greatly appreciated. Thanks :) (y)
Cabinetman
5 Jan 2017
lincolnshire Wolds
I was helping at my brother-in-law‘s eco-house recently and the T and G, OSB board was just laid straight onto the Celotex, glued to it but the osb panels weren’t glued together which I think they should’ve been. No movement in the floor whatsoever, jump up and down on a bit of Celotex it’s very resilient. Ian
Molynoox
17 Jan 2021
Billericay
I would be interested in the result if you do this - I wouldn't be brave enough to try it, because if it doesn't work out then its either a very big and expensive fix, or you have to live with floor movement forever. Sorry that's not much help.
Martin
mikej460
19 Jan 2019
Daventry
Ditto above. I've laid chipboard directly onto Celotex and glued the tongues and the floor is solid and warm.
MARK.B.
4 Jul 2012
East Yorkshire
50mm celotex and 22mm boards on top will be rock solid underfoot , never seen it but it but I think it would take tremendous weight and force ,far more than any you or your machines could exert even if you tried. I used two layers of 9mm ply sheets on my shop floor ,bottom layer just laid in and top screwed to that , expansion gap of around 10mm just in case round the edges , its never moved and nice and warm/comfortable underfoot.
Rob Cheetham
11 Sep 2018
chaddesden derby
Thanks everyone for the advice. Sounds like im just worrying over nothing. Got chipboard delievered yeserday. Will get laid when my job gives me a break (sure alot of you can relate 😂 )
Thanks again
Sheptonphil
Scrumpy junkie
29 Dec 2012
Somerset
Thanks again
You’ll be fine. My workshop has exactly that, 22mm chipboard on 50mm celotex. T&G glued with D4. Membrane between chip and celotex.
I have a Jet 3520b lathe, 340kg, plus 60kg of blanks stacked on it. No problem and lathe is solid. The floor ain’t going anywhere. The centre island workbench is 100kg.
Jones
5 Oct 2021
Gwynedd
It's called a floating floor and is common. The t&g joints should be glued and leave enough room (10mm+) all round for expansion of the timber, you can fill that gap with cork strip or use a skirting to cover it. Make sure to buy flooring grade celotex/kingspan which has a high compressive strength.
Rob Cheetham
11 Sep 2018
chaddesden derby
@Sheptonphil thats good to know. Looks like your definetly into your lathe work with that beast haha. Like what you have done with the space. I have ended up going a step futher and ordered 7mm workshop interlocking floor tiles to go on top of the chipboard. Can handle car jacks engine hoists etc so will deffo be good enough for my machinery.
Seems a smallish shop like mine. What size is it. May take some inspiration from it lol
Rob
Rob Cheetham
11 Sep 2018
chaddesden derby
@Jones thanks for the advice. Yes I was going to leav about 5mm but im glad you said as will now go for 10mm+. Am going to put skirting round once done to cover the gap. Already bought the celotex a while back so heres to hoping it is. Its already down and easily walkable on so think ill be alrite. Thanks again
Rob
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
Sheptonphil....
I like ur w/shop....alas my units will be cast off kitchen units.....
bet u had fun with all the drawers....hahaha...did u use bearing type slides?
I once had a w/shop with that kinda floor....
I used an oil based Sikkens product to seal it....it was a bit like decking sealer...made is nice to sweep up.......when I sold the house I redid the w/shop floor....I know it helped with the house sale....it's not always the woman that decides.....in fact every house I have fixed up n sold always got a decent smart workshop......often just old kitchen units but with the right lighting and decent decorating it sure makes for an easy sale......
Sheptonphil
Scrumpy junkie
29 Dec 2012
Somerset
Rob
It’s my escape room 😉 I can spend hours in there quite happily.
Internal dimension is 3.8m wide, 7.4m long. I then put a separate room at the rear through the door with the dust extractor (piped throughout the workshop), sink, compressor and welding bench. The best thing was the 50 drawer system I built as storage along the right hand side. slim and medium drawers are so much more efficient as accessible storage than cupboards or shelves. Tools in cupboards or on shelves don’t work. The storage above the right bench is french cleat with custom holders for aerosols, glues, lubricants, and all manner of things.
I bought the lathe from Axminster as a retirement present to myself. I re-kitted the old workshop out in my last year of work knowing I’d never get the opportunity to spend that sort of money on tools again. I upgraded the bandsaw, lathe, pillar drill, Mortiser, table saw, belt/disc sander, linisher, thicknesser, routers and track saw in one year. All quality tools that will see me through and probably step son as well when I’m gone.
