Flanged bushing search
rodisi
13 Jul 2017
Germany
A bushing has broken in my Black and Decker KS531 jigsaw. My two options are find and replace the bushing or throw an otherwise perfectly good jigsaw away. The latter makes me cringe, the state of the Earth and we are throwing valuable resources away. The problem is Black and Decker do not sell parts for this jigsaw. I'm hoping someone on this forum can answer two questions. Does it matter if I use a bronze or steel bushing and any ideas where to look for such a bushing.
Thanks in advance
AES
18 Feb 2011
Switzerland, near Basel
I agree with you 110% about chucking stuff away.
I'm guessing the broken/missing "bushing" on your tool is a sort of "dull golden/copper/slightly speckled" colour? In which case it's not "just" a bushing, it's a bearing too (probably for one end of the motor shaft). In that case, YES it definitely DOES matter and you MUST use Phosphor Bronze, NOT steel. The reason is that P-B is slightly "spongy", is pre-soaked in oil before factory assembly, and being spongy, it holds that oil for a long long time. So you need the same material.
If you've found that official B&D spares are no longer available, I'd suggest:
A) Google for companies that specialise in supplying spare parts for electrical tools. There are several I believe (though I don't know any off hand, sorry), and such firms often hold all sorts of weird and wonderful old spares parts;
B) From your drawing it looks a dead easy machining job for anyone with a lathe. Got one yourself? Know anyone with one? Any "jobbing engineering shops" near you? Any model engineering (especially steam) clubs near you?
C) Long-shot: Look for someone selling the same tool as yours SH.
Whereabouts in Germany are you?
ChaiLatte
12 Mar 2022
UK
Closest you will get in standard Oilite is AL 07 11 08. Buy two, file the flange down on the one and set them back to back with a 1.5mm thick spacer, ID 7.5mm, OD 11mm betwixt. A standard bush in the dimensions you want is not made by Oilite.
As an alternative, to save filing, buy one AL 07 11 08 and one OB 07 11 08.
rodisi
13 Jul 2017
Germany
Actually, it looks like dark steel
I lived in Germany when I registered on this forum but now I'm in Kent, UK.
What is the thickness of the flange wall ?
Stupidly, I missed that one measurement. I shall have to dismantle it again and check.
gcusick and ChaiLatte, thanks for the info.
rodisi
13 Jul 2017
Germany
FYI, I found the housing assembly that contains the bushing in the Spanish B&D website.
€4.95 - Excellent but they won't ship to the UK. I'll send it to a friend in Germany, who can forward it to me. Postage to Germany, €20 add tax for a total of €30 and then it has to be posted here and then maybe import tax?
You've got to laugh.
deema
14 Oct 2011
chester
I’d be curious what the metallurgists think it is, my guess is cast iron as it would self lubricate. How did it become two parts?
okeydokey
21 Nov 2014
West Sussex England
This may be/sound daft but if the broken part and the round part don't have any rotational force on them - I assume not as its just a self lubricated bush - then why not join them together with araldite or better still JB Weld?
Well worth trying let me know what do you think?
chaoticbob
14 Nov 2012
Wirksworth
Not a metallurgist, but that was my guess (based on the appearance of the fracture) too. Steel just doesn't break like that.
rodisi - I'm all in favour of fixing stuff rather than junking, but it seems crazy to pay €30+ for a part that would be so simple to make. If you don't know anyone locally with a lathe I'd be happy to do it for you for the cost of postage. PM me if interested.
Bob.
rodisi
13 Jul 2017
Germany
I've got some Gorilla glue. I shall try it.
Bob.
If the Gorilla glue, above, doesn't work, I may take you up on your offer. Thanks
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
I'm sure u'll find it's Sintered iron.....almost like Bronze.....
It's also impregnated with an oil lube......
To use a cast iron bush in a high speed envoiroment take special engineering finish.....
The VB36 wood lathe use a cast iron bush instead of bearing in the head stock.....
BUT like those in gas turbines they are very special....
Not for Black n Decker.....lol.....
chaoticbob
14 Nov 2012
Wirksworth
I think this must be right - having the broken part in my hand it's too light even to be solid cast iron. Density is 5.8 (+/- 0.1) grams per cc, so probably ~ 20% porosity.
Thanks clogs, I didn't know about this stuff, One lives and learns!
Replacement will be in SAE 660 leaded bronze, I reckon it'll work OK but we'll see - low cost experiment.
Bob.
