I have to fix a cistern to a wall that is not flat and imagine it's a common problem faced by plumbers in particular so I wonder if there is a purpose made adjustable bracket that is available to buy ?
Is this a close coupled toilet? If close coupled then the weight of the cistern is transferred through the pan, the cistern fixings just keep it to the wall so you could then use rubber spacers and pull the cistern to the wall as evenly as possible. If not then look at scribing a piece of wood to the wall so it fits flush and then attach cistern to this. All depends what sort of finish you are looking for, I assume not tiled!
Hi Thank you for this. It's not a closed coupled cistern. The wall is not a different shape so much as it slopes so the distance required on one end of the cistern fixing will be lets say around 11/2 inch and the other screw would be around 2 inches long - it varies. I hope this explains. I will try to scribe a piece of wood and fit to that then. Thank you for the tip.
I have used rubber door stops for this before, easy to slice them to the required thickness to fit between the back of the cistern and the wall.Is this a close coupled toilet? If close coupled then the weight of the cistern is transferred through the pan, the cistern fixings just keep it to the wall so you could then use rubber spacers and pull the cistern to the wall as evenly as possible. If not then look at scribing a piece of wood to the wall so it fits flush and then attach cistern to this. All depends what sort of finish you are looking for, I assume not tiled!
