Fitting a woodworking vice to workbench
Wilson joinery
25 Feb 2022
Durham
Afternoon everyone
Do any of you happen to have a recommendation for how to correctly fit a vice to a workbench (it’s a record 52 1/2 if that makes any difference). There’s so many videos on YouTube but I’d prefer to work from a woodworking book if anyone knows of one I can try and get my hands on. I guess there’s probably more than one way to do it, but my last attempt wasn’t overly successful so I’d like to follow some proper guidance this time.
Many thanks
Main thing is to turn your bench on its back so you can install the vice on to a handy horizontal surface. Much easier.
Or failing that, lock the vice to a couple of 3x2's at the correct height and stand it up in-situ.
Mine is just bolted through the bench with 4 recessed bolts (the two additional holes in the bench are from a previous vice), washers in the recessed holes to stop pull-through and washers under the nuts on the underside of the vice - the inner jaw is recessed into the bench edge, with a sacrificial pair of plywood jaws - the inner jaw about 3mm proud of the bench edge. The top edges are obviously flush with the bench top.
My other vice (!) is a Record engineer's vice on my bicycle repair bench - it has a pair of clever magnetic plastic "soft jaw inserts" for gripping threads etc. - quick to fit and remove
Thanks for the help guys, I remember fitting my last vice was a nightmare as I was trying to hold it underneath the bench while trying to get the bolts through the holes I’d drilled lying on my back and nearly giving myself a hernia 😂
Most importantly, make sure the vice works at multiple distances without jumping out of the thread under great pressure.
Not all vices are as good as they used to be.
Cheers, Andy
...I was trying to hold it underneath the bench while trying to get the bolts through the holes...
You will not be arrested by the vice squad if you use some different bolts* (specifically allthread studding) to haul the vice up into position before putting in two of the proper bolts.
* or even rope
I'd search for the Paul Sellers video on installing a vice, most would consider him an authority on the subject.
* or even rope
Or just turn the bench on its back
He is good, yes, BUT his idea of not having the back face flush with the front face of the bench is to me definitely not right! And would drive me nuts.
I have always sunk the rear face into a big mortise in the underside of the bench, and no bolts thank you, coach screws work perfectly.
Yes to tipping the bench, or as I’ve always done just undo the top from the frame.
Last time I fitted a vise to my bench, I used a six inch wide L shaped piece, held the vise roughly where I wanted it, then put the L shape in the jaws, such that it was pointing back over the bench top, tightened the vise and it was held in place well enough for me to mark for pilot holes and then mount it.
Where did you get those vise covers?
Temu - search Magnetic Vise Jaw Plate Set - they were £3.69 with free postage (in a minimum postage -?£15 - bundle with a couple of other things) They do different widths, I bought the wrong size as they protrude from the vice jaws - but not really a problem.
This is a pic of how I think it should be done, clean and flush with the front face.
View attachment 196383View attachment 196384
So, did you dismantle the vice and feed the screws and stuff through the apron?
The workbench I made for the dry dock, my workplace, 10-15 years ago has a protruding vice a la Sellers, but I’m about to make another on for my shed at home, and am thinking if doing it flush this time. Tbh, protruding is fine, and I wouldn’t bother changing it, but I can see the advantage of having it flush, especially for long boards, although, ironically I often work long boards at work, and am unlikely to do so much at home.
I’ve been debating whether to mortice out the front of the apron to set it in, however I’m worried that if I do that, and do it deep enough to put a cover plate on it, I’ll compromise my apron too much. The only downside I can see with your set up is that you lose some capacity, though very rarely, if ever, do I need the full width of a 52 1/2.
Yes I was being a bit fussy and took it apart, I could have cut a bit more of the apron off and made life a bit easier. And yes it does lose a bit of the capacity but as you say I’ve never opened it all the way in anger either.
That bench top is 2 3/4” thick about 12” wide and 10 feet long, I took it off and turned it upside down to dig out the long mortise to drop the back jaw of the vice into, fed it through the Apron which was fastened to the bench top from the back and screwed the vice to the underside of the bench top with Coach screws and washers. Really solid.
Damn heavy by now so my Son helped me spin it over and into place.
Ian
