Fitted bedroom furniture
mikefab
14 Jan 2013
Hexham, Northumberland
Here are some photos of some fitted furniture I made for my neighbours. It's the first time I've done work for somebody else so it was an interesting experience taking their ideas, building on them / moderating them and turning them into a design for approval.
Timber Ready for face frames
Ripping down some oak for the worktop.
Stickered in the house for a bit
Face frame glued up (sycamore, was very cheap as some mould stains)
Carcasses in production on the driveway
Face frame test fitted to carcasses in my front hall to allow door fitting.
Solid oak drawer boxes made from local 3/4" northumberland oak (offcuts friends at local joinery firm). Bases from 6mm oak veneered mdf. Drawer sides joined with groove/rebate and PU adhesive. Man the squeeze out was a pain... finished with osmo Poly X.
Doors glued up from 22mm MR MDF
I didn't take any pics during the install apart from this!
Finished project, all components hand painted prior to install to minimise time and mess on site.
There was a little touching up of filled nail holes in the skirting after these photos but that's it.
Runners were blum tandem soft close, hinges blum clip top blumotion. Paint was Dulux trade eggshell (oil based by mistake!). Carcasses were Egger MFC (very heavy!!).
Thanks for looking!
Mike
Very professional fitted furniture.
I probably would have made 2 front frames for ease of making and fitting. Less risk of an Oops moment when it wont go up the stairs.
Thanks very much Robin.
I think I'm with you on using two separate face frames in future. I wanted to achieve a totally seamless look which is why I did it as one frame, but it was a pain at all stages of production and needed handling with care! I think in this case two frames would probably have looked ok because of the change in height at the transition between units.
Great job, looks like a professional job. Only thing that bugs me is the handle placement, I would have put them in line with the rails but maybe that's just me.
Thanks for the feedback everyone.
Woodmonkey: definitely take your point. Thanks. They did feel a little low when lined up with the the midrails though. The midrails were positioned to line up with the top of the drawers - not sure if this is the usual approach but it made sense to me.
To be fair you've got reduced height doors due to the sloping ceiling so you're probably right
I've had a question by PM about the models of hinges and runners used. For the greater good I am answering via the thread! Hardware came from M&D Online.
Hinges and mounting plates:
CLIP top standard hinge 71B3750 (71B3750)
CLIP hinge mounting plate - 174E6100.01 (174E6100.01) = £2.10
Runners:
TANDEM BLUMOTION - 550H4000B (550H4000B)
Also, face frames and doors/drawer fronts were 22mm thick.
HTH
Mike
As others have said, top job. I particularly like the drawers made from the oak, handy friends you have there!
Terry.
