johnnyb
After some delay.such as building the dwarf wall. I've now sourced the wood. I drew the rods out last week. today I thought I would try a mortice and tenon.
on a 6ft post and a 5ft bottom plate.
it went really well. I drilled with a flat bit and chopped. I used an old makita 235mm saw for the tenons made many cuts snapped them then planed with a rebate plane. it worked beautifully.
the weight is the biggest issue.
for instance I tested the fit got slightly stuck and struggled to get it out again. eventually I used wedges going forward and back till it popped out.
one concern is I've got a 6 by 10 beam and I intended to make an arched tie beam but its really heavy and I've no idea how I would start to cut the arch top and bottom . any body got any more hints.
