fire extinguisher
That would work
29 Dec 2018
Dartford
Hi
My workshop is small but quite nicely formed so would like to keep it that way!
Its about 17x8 feet. What type and size of fire extinguisher would be best?
Tim
sunnybob
wysiwyg
11 Oct 2014
cyprus
Fire extinguishers are sold by what material you want to put out.
Wood, electrical, chemical, etc. if your workshop is just wood with the standard electrical supply. Something that stands about 3 ft high and is made for wood should serve you well.
Bear in mind H&S requires fire extinguishers to be wall mounted near exit ways and have the handle 1 metre off the ground. (or they did a dozen years ago) :roll:
lurker
Le dullard de la commune
2 Mar 2007
Leicestershire
In a workshop you are bound to be involving electricity even if only indirectly.
Have the extinguisher sited near the door so you have your back to the exit and safety.
Mike Jordan
21 Apr 2016
Derby
I would recommend a six or preferably nine litre AFFF extinguisher sited as suggested on the escape route. Electrical fires are sorted by turning off the machine either at the socket or fuse board. The burning material is then safe to deal with. Google AFFF and you will find that it is also suitable for dealing with flammable liquids.
Extinguishers are cheap to buy providing you don't go to a firm describing themselves as providing fire safety services or extinguisher maintenance.
The most expensive mistake would be signing a service agreement of any kind.
