Hi there, New to the forum (and woodworking), so be gentle
I am building a scrabble set! I have had the pieces cut in birch plywood, with engraving and rastering details on both the board and pieces.
Birch plywood is light in colour, and I am looking to dye the wood to a darker colour, perhaps something similar to cherry. I however also want the engraved and rastered areas to be painted white.
I found this helpful tutorial online, but i am unable to share links
It basically was a process of painting over the wood, then sanding away the excess paint, leaving only paint in the engraved/rastered lines.
My question is this: would this technique work on dyed wood? Would I still need to use a sealer?
If this is no good, how would you fine folks recommend me to do this?
Thanks in advance,
Nick
Thanks in advance,
Nick
