Finish for apple?
Alf
22 Oct 2003
Up the proverbial creek
Asked more in hope than expectation; anyone got any experience of finishing apple? Finish of choice? Searches are bringing up not much.
Cheers, Alf
Just nibble back to the core, avoid the pips, and pop the lot in the compost.
Can't see the problem really :D :D
(Sorry. That didn't help did it Alf :oops: )
Can't think of a better way, Aragorn. :lol: :lol: :lol:
Only problem is when there's just half a maggot left in the core! :shock: :roll:
Sorry, Alf, not much help I 'spect.
Cheers,
Trev.
Ahh! I see what you meant now Alf :wink: :roll:
Was wondering why this wasn't Off-topic :D
Can you not finish apple like any other wood? Oil finish?
What might go wrong with using finishing oil or danish?
Please let me know what you find out, as I want to use some apple soon myself.
Ta
Yeah yeah, pull the other one, it's got bells on...
Well yeah, but sometimes there's a finish that particularly lends itself to bringing out the best in a particular timber, and rather than reinventing the wheel I figured I might as well ask (a decision I now regret... :p). Looking pretty firm on shellac now 'cos I fear oil may make it too yellow in time.
Cheers, Alf
Didn't Citizen Smith's mother used to polish them with Pledge....? Think she's now Alfiie Moon's mother in Endeasters.....
Noel, always helpful
Alf, it depends what qualities you're after. Are you requiring super durability, toughness, resistance to alcohol, water spillage or water vapour exchange? Then an epoxy finish might suit the bill.
On the other hand are you looking for a soft tactile finish that perhaps doesn't have some of the qualities listed in the first paragraph? An oil or thinned out soft varnish like danish oil might suit.
From a later posting you made in this thread I gather you want to retain the original apple colour as much as you can-- but still, what other qualities do you require?
Shellac is a brittle finish that doesn't resist alcohol, is quite reasonably water resistant, but it is easily repairable. To retain original wood colour as much as possible use a super blonde de-waxed shellac. Dewaxed shellac cures harder than the waxy varieties and offers better protection against liquid ingress.
If you want better protection then the super blonde dewaxed shellac is still a good start as a first coat because it gives the wood some warmth colourwise, which is important as you'll see as you read on.
Any other film forming polish can be applied over dewaxed shellac, even water based polishes which are notoriously sensitive to impurities underneath them. So, you could follow up with water based varnish (polish) which dries clear without the yellowing or ambering seen in oil based varnishes.
The problem with water based finishes I've found is that the manufacturers still haven't got the formulation just so. They still tend to dry with a milky look about them, and often have a blue cast and can look rather flat, cold or dead depending upon your prefered term.
They are often formulated with good UV (ultra violet) blockers, and because they are a reasonably effective seal around the wood they reduce the passage of air and vapour (gases). UV light and oxidisation of wood constituents lead to wood colour change.
So, you can warm the colour of the wood with the shellac, and give more physical protection with water based varnish, but there is a bit of a twist. Water based varnish is not the easiest stuff to apply well, and it's not all that easy to fix down the road.
With every benefit comes something of a difficulty, ha, ha. Slainte.
Ah well, if that was a vital aspect it'd have made the decision that much easier. As it is I shall go with the shellac*, and as you say, I can always get creative over it if I need to. It was just on the off-chance someone would come up with a "Oh you want to use X, it works brilliantly with apple" answer really. Thanks for the detailed reply though, and I know exactly what you mean about a "dead" look to water based. Shame, 'cos it's handy stuff.
Cheers, Alf
*Blonde, de-waxed, mixed it myself - fear not. :wink:
waterhead37":1jgbqarz said:
I look forward to seeing the finished shave. :)
See if you still feel the same way once you've waded through the whole painful, step-by-step process in words and pictures... :wink:
Cheers, Alf
Midnight":2bd8kel1 said:
<speculating..
replacement Diston handles..????
Chris was on the money (although whether that was luck or judgement..?), although the apple was originally bought for saw handles as it happens.
Cheers, Alf
