Advice please.
I have a router table (Trend) and have been asked by another tenant at the place my workshop is to use his Rockler finger-joint jig (this one)
www.rockler.com
to make some small boxes for him. He gave me his home made router table, with installed bit to use.
The supplied bit is an edge trimmer, complete with bearing on top, and the supplied table doesn't have mitre slots for the jig so I will be using my table and bits.
The width setting blocks that come with the jig are imperial, and all of my bits are metric.
So I need to buy a 1/4" router bit to make finger joints, but I don't see any future use for it so it must be cheap. It'll only be going through thin, soft wood so needn't be the highest quality.
I should add I did make my own setting block from a scrap of hardwood to fit the jig and be the same width as my 6mm bits, but I don't think it will stand the test of continued use as well as the supplied metal blocks.
What do you recommend please?
Rockler Router Table Box Joint Jig
Make strong, tight-fitting box joints on your router table—great for small- to medium-sized boxes!
