Fine cross cut 254mm Tablesaw blade
Petey83
19 Mar 2014
Enfield
Maybe my Googling skills have failed me but I'm really struggling to find a decent 60t crosscut blade in 254mm for my table saw.
I ordered one from Axminster but it's arrived and packaging states it's for mitre saws so assuming wrong take for a TS.
I can find plenty of 250mm blades bit not any 254....
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
Just put a 250mm blade in, you're only losing 2mm of cutting height. Saws come specified as 254mm (10") maximum blade size since they usually trying to cater to the American market because they still use imperial measurements e.g 216mm (8.5") or 305 (12").
What are you planning on cutting with such a fine blade on the table saw?
May I suggest a brief look through this thread? :) :
https://www.ukworkshop.co.uk/forums/a-guide-to-circular-saw-blades-t119811.html
Petey83
19 Mar 2014
Enfield
I want it for finish cutting the ends of the serving boards, especially ones where I use epoxy.
I was thinking a 250mm blade as I rarely get close to max depth of cut on a serving board
Trevanion
29 Jul 2018
Pembrokeshire
I suspect the blade you've bought will be fine for the job, any blade you can put in a mitre saw can be used on a table saw with no real ill-effect but it doesn't work the other way, a ripping blade designed for use in a table saw will be horrendous in a mitre saw and will cause the sliding head unit to snatch the timber.
Petey83
19 Mar 2014
Enfield
Thanks.
I've got a 254mm ripping blade from Axy at the same time as I've got a oak butchers block project waiting to be done and that's going to be some deep rips
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Erm, unless it's just me being thick because it's late, I don't think that that is true. A negative-rake blade designed for use on a RAS or SCMS will LIFT the workpiece if it is used on a TS, because it is designed to push the workpiece away from the centre of rotation.
It IS true that a TS blade on a SCMS will be rather aggressive and does need to be firmly controlled.
Get a +ve rake 250mm blade and you will be fine.
Trevanion
29 Jul 2018
Pembrokeshire
I think you'd have to be really pushing the stuff through to get it to lift up off the table, there may be slightly more cutting resistance pushing against the operator but the cutting force is still acting downward onto the table for the most part. I've got a negative TCG blade that I use for ripping melamine occasionally and I've never experienced any problems like that.
Petey83
19 Mar 2014
Enfield
I've actually ordered an 80T from Key Blades and Fixings.
On them as a company - super helpful and blades seem to be really top quality.
MusicMan
1 Jul 2015
Warwick
I don't think you are being thick except maybe about the TS blade on a SCMS! The TS blade is designed to pull the workpiece towards the centre of rotation, so will be dodgy on a SCMS, and even if it didn't pull the workpiece up, would give a less clean cut. So I think one should use TS blades for TS and SCMS/RAS blades for those.
Keith
Sideways
26 Dec 2017
United Kingdom
Slightly tongue in cheek crack there. I suggested 80T because that's what came on my own 10" mitre saw back in the day and when I made my first ever cut with it, I was more than happy :)
Thanks for the recommendation.
