Fine air filter
Jameshow
4 Oct 2020
Bradford
Anyone think this would work as a decent fine air filter with a 4/6" fan in the opening?
Cheers James
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
It would probable work but you should find out to what level it filters and skip it if it doesn't filter to 0.5 micron or 1.0 micron at the most. If you can find a squirrel cage fan like central heaters use and put one on each side of the housing it will suck through the filters. The dust will be on the outside and you can clean it when it builds up. Blow into the hole and it fills with dust and becomes much harder to clean.
Jameshow
4 Oct 2020
Bradford
Great thanks for the directional tip!
Sandyn
19 Jul 2020
Scotland
These filters are for engine air intake. Large industrial engines. According to a Donaldson air intake catalogue, I think these filters are 'standard' they generally remove around 96% of contaminants. I Really doubt they will filter down to 0.5/1 micron level. I think the filter would need to be blue, or two stage filtering. If you want to get up to 99% +. I don't think they will do it. (£12?) If this is what you are trying to achieve. I would not risk using them without confirming their performance. Depends what you mean by fine air filter?
DBT85
19 Dec 2015
Pershore, Worcester
An engine is far less concerned about getting 10 micron contaminants in than your lungs are. An air filter for engines is to keep the bigger stuff out that is going to ruin the engine.
What's the intended use?
Cabinetman
5 Jan 2017
lincolnshire Wolds
Whilst it would be nice to have no dust in the workshop, imagining that you are ever going to reduce the particles in the air in your workshop down to subatomic size is fanciful at best. It’s horses for courses, aeroplanes change their air through HEPA filters four? times a minute, I’m sure operating theatres are similar, we are talking about just not having piles build up in untouched places here. Not sure about those filters James but better than nothing I’m sure.
Ian
Jameshow
4 Oct 2020
Bradford
I should just put my DX outside so the fine particles are outside of the workshop rather than inside.
I really need to sort out my workshop with insulation power and lighting.
Cheers James
baldkev
29 Apr 2020
devon
The only downside to putting the dust outside, is that you loose your heat very quickly when the extrator is on. I still havent got mine done ( the cost of the motor, vfd plus ducting etc ) but mine will vent into an outside dust shed.... and I'll be cold during the winter! 😆🤣
Inspector
18 Jun 2006
Ah but your cold isn't really all that cold. It barely stays under 0º for very long at all. 😉 I know I know it is a damp cold. 🥶
Jameshow
4 Oct 2020
Bradford
Good point. Maybe a job for spring!!
