Hi brain trust
Quick question re solid wood edging on plywood. I’m about to do this and I’m anticipating having some hairline gaps to fill when done. I’m going to paint over everything so a colour match isn’t important, however getting a glass flat finish is.
I’ve had a look through previous posts, and seen a lot of people seem to be recommending car body filler, so I’m assuming this is the way to go in this instance too (could well be wrong though??). If so is there anything special I need to do to it for this application, for example as it’s likely to be a hairline gap, should I dilute it so it flows in a little easier
Thanks in advance
Jim
Thanks in advance
Jim
