Fibonacci gauge
mtr1
10 Oct 2009
North Norfolk
So I'm going to make one of these, and wondered where to but the little brass rivets? I've had a look in my local shops but can't seem to find them, I google brass rivets but couldn't find the ones I wanted either. They are about 10 mm long and and have a male and female post any ideas? Thanks in advance :)
Hi Mark
I've made a couple of these as gifts.
The rivets were simply peined brass rod and brass washers ...
Pein one side, cut to length, insert, and pein the open end.
Regards from Perth
Derek
As I've never heard of this sort of gauge, what's it for?...just curious - Rob
Thanks Alf, I've ordered brass rod and washers to do it Derek's way but have ordered the rivets anyway. So I will make one for Rob If he pm's me his address, you can have a play then :D
Mark...fantastic :D PM sent - Rob
Harbo":1sjo9ebw said:
Rob - it's for marking out the "Golden Ratio" 1:1.618
Rod
Rod, thanks for that info. I'm aware of the GR and use it a lot in my work, but I didn't know there was a special bit of kit to mark it out...you learns somat every day! :lol: - Rob
And a lot of brass on the floor too, one assumes. What's the market like for brass at the moment? Most metals seem to be through the roof, as I understand it.
Yes for example 3mm diam £1.30 per 300 mm length.
Generally sold at current Market price per Kg.
Rod
You've just got someone completely intrigued in Fibonacci!
Anthony
Someone decided that the Fibonacci Mathematical sequence was useful for working out progressive gambling stakes.
What they didn't consider was it really works best when you pick winners! :D
John :) !
Prototype before I break into the good timber....
Few things to sort out, the middle pointer is about 3mm short.
bit of fun..
I'm going to get some more cutlers rivets, when I make the pair as I didn't get on with the brass bashing.
