Ferm 600W Tile Cutter - short review
RogerS
20 Feb 2004
In the eternally wet North
Costs £40 from Screwfix. Comes with a rip fence and a mitre cutter. The saw blade (diamond) is tiltable. Water bath keeps the blade and workpiece cool.
So far so good. What really lets this down is the fact that the motor axis is not remotely at 90degrees to the fence and no obvious means to correct this. Sighting down the blade shows that it is about 3-4 mm out from front to back. You can just about accomodate this by skewing the fence to compensate but only just and it takes a LOT of brute force to make it parallel to the blade.
Had I realised this before I started using it then I would have sent it back.
Roger
jasonB
26 Nov 2004
Surrey
Most of the Plasplug ones have the same problem, I just mark the tile & guide it through by eye.
Jason
tim
5 Nov 2004
Herefordshire
Roger,
You can normally tilt the guard up enough to get a reasonable sight line without getting a free face wash! Sadly its a matter of trial and error.
Tim
jasonB
26 Nov 2004
Surrey
As Tim says have about a 2" gap at the front of the guard and develope your techneque so you can guide it through while keeping your head to one side of the blade, do tend to get a wet crotch though :(
Also don't overfill otherwise you will spray water everywhere.
Jason
jasonB
26 Nov 2004
Surrey
I have heard that it's OK but a bit limited on the size of tile you can cut. Better to save up and get the Rubi LP200LP. :D
Jason
cambournepete
29 Mar 2004
Rangiora, South Island, Aotearoa
I've got a "cheap" Rubi cutter. Their larger ones will cut tiles you describe but 15mm thick diagonally...
Mine is very easy to use - rather more than the cheapo copies, but far better and more confidence instilling, which is quite useful for tile cutting...
jasonB
26 Nov 2004
Surrey
My Rubi manual tile cutter will take a 1" strip off a 500mm porcelain floor tile no problem, also fine corner to corner on 300x300 porcelain, even easier on ceramics.
Jason
