Ive done a couple of these now, will post some pics.
RE the insert plate, I have bought
2 of these from eBay for my Triton routers - I know you have to drill them, but I find them really good and strong.
Basic shape dry put together
Front panel slot cut to allow fixing of movable fence at the front
Glued up (blocks to keep is square while gluing)
Cover made to form a dust extraction port
Pair of panels cut to form the front fences, with threaded inserts added
Finished main section (nothing to stop you stopping at this point if you dont want the movable fences) (pic also of the router insert I linked too) - note also the hole to add a vacuum for dust extraction
Complete unit with fences attached - these can be moved to suit the size of the bit your using
Adjustment knobs on the back that screw into those threaded inserts I added earlier too lock the front fences in place
