• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale Felder K700 Pro Sliding Table Saw
Peter Sefton
Wood Workers Workshop
UKW Sponsor
6 Jun 2011
Threshing Barn, Upton-upon-Severn, Worcs WR8 0SN
Felder K700 Pro Sliding Table Saw with Scoring Saw, Dado shaft and overhead guard. In excellent condition after very light use in teaching workshop. No rust or damage on the machine. The 4 HP (3 KW) has plenty of power from a 16amp single phase supply. The 315mm blade gives a cutting height of 104mm at 90 degrees and max rip width of 1220mm via the fine adjustable rip fence. The high/low rip fence is fully adjustable in its length and offers excellent work support and gets in close when the blade is tilted and guarded within the wider guard shroud. Safety features include 10 second breaking, micro switched blade enclosure, overhead swing away guard which gives full protection for panel cutting, dado work and tilt arbor cutting. The additional foot operated off mushroom button is a great when your hands are full for added safety. The 120mm scoring saw unit can be wound down and adjusted for blade alignment (only used once so in immaculate condition) Even when fully loaded the robust 2050mm X Roll sliding table glides with ease. The crosscut fence can be set at the front or back of the 1300mm professional carriage with fine adjust repeatable 90 degrees stops or pre marked degree angle cutting. The pair of flip length stops are robust and easily read from the mm fence scale and can be used on the extending length support. A very accurate and robust industrial machine weighing 560 Kg. Suitable for a commercial or hobby workshop, in perfect working order and can be tested before purchase.
£5200 plus VAT £6240 inc VAT Collection from WR80SN can be seen working
Peter
I have the Felder 700 (smaller) version of this saw.
It’s well made and has very ridged fences.
I tried everything from SCM, Axminster, itech, altendoroh, in this range (sub £10k) and this saw came out as the best.
It was the strongest and sturdiest, with the features I wanted (mine is all electric).
You won’t find anything new, that would compare with this for the same price (ime).
Good luck with your sale Peter.
