clive griffiths
I am looking to see if anyone has come across a shelix cutterblock fitted to a felder planer, as there is one on ebay at the moment.
Clive.
Clive.
Clive.
I've been back to Felder a few times, seeing if they'd retrofit a spiral block to my machine. The answer has always been no, they're only available on new machines.
I've heard from a Felder engineer that there's no technical obstacle to retro itting a spiral block, so I can only conclude it's a marketing decision.
I still hope they'll change their position, but as of about eight or nine months ago it was still an emphatic "no".
Did they give you a reason Custard, I’d guess they’re not geared up to do this on site or back at the U.K. headquarters so would need to send it back to the mother landI've been back to Felder a few times, seeing if they'd retrofit a spiral block to my machine. The answer has always been no, they're only available on new machines.
Hi ollie, forgot to say this one is probably a scam.I wonder if you could just order the silent power block as a "spare" part then fit it.
I would say the starting bid is a bit much, considering there is another ad741 on ebay for £4200 with the silent power block...
Ollie
I have had an ad 731 since 2003 new and have thought about changing to a shellix block but have shelved that idea (and the one on ebay) I nearly purchased a new felder 300mm planer early this year but found out that it was the only planer thicknesser that is not fitted with any springs to assist with lifting the tables.
Certainly all the older Felders I’ve worked on have been spring assist, some have double springs. Once this covid is over a mate wants a hand putting springs on the tables of his Felder combination machine, it doesn’t have them & it makes lifting them a bit of work.Are you absolutely sure about that? I'm fairly certain all Felder planers have a gas-strut lifting system and lifting the tables is near-effortless.
I would be interested to know what model your mate has , i went to see a 531 combination and realised how much lighter in build the planer was to the 731 i guess you have got to go up to the 741 to get the spring assisted.Certainly all the older Felders I’ve worked on have been spring assist, some have double springs. Once this covid is over a mate wants a hand putting springs on the tables of his Felder combination machine, it doesn’t have them & it makes lifting them a bit of work.
Yep it’s the 731 here it is in thicknesser mode showing no spring assist, fortunately the tables aren’t that bigI would be interested to know what model your mate has , i went to see a 531 combination and realised how much lighter in build the planer was to the 731 i guess you have got to go up to the 741 to get the spring assisted.
Talking to other woodworkers in this area there's a clear divide opening up. Furniture makers are loving the spiral block, joiners are a lot less enamoured. The issue for joiners is twofold. They can't get the really deep thicknessing cuts that they want, and also because they tend to wear their knives further before replacing they say the blades on the spiral block will only give them two "turnings" rather than four. On a well worn spiral block knife if you just rotate the knife through 90 degrees you end up with one of the well worn sides at the corner, which then leaves a line on the workpiece, similar to if you chip the edge of a traditional planer knife. Instead of turning the knives earlier they're turning the spiral block knives through a full 180 degrees. hence only yielding two sharp edges per knife instead of four.
Are you sure you’re not confusing this with the gas strut on the power feed on Felder combination? Whilst I’m certainly no expert on Felder machines I’m wondering where you could place a strut under the table that wouldn’t foul thicknessingThat’s crazy! They decide to join both tables together to make them twice as heavy and do away with the gas-struts? What the hell were they thinking?
