Feelings about lathe rigidity ?
Grahamshed
14 Apr 2012
Oxfordish
I am building a cupboard affair for my lathe, All my other cupboards( for router table, mitre saw etc ) are on 100mm lockable castors. Would tho be OK for the lathe or does it need something more rigid. Castors, even locked, can rock a bit.
I would think that stability would be a problem with castors on the lathe bed. Most people have to weight the bottom of the bed or secure it to the floor to increase stability .
Vic
I have a base on castors we used to use at the local club. It was never really stable enough because of the castors but I guess a wide enough base would improve stability. Some clubs I have been to have retractable castors and some just chock up the base on two lengths of 4x2 which improves stability no end!
Hi
If you need to be able to move it then fit castors, but fit them in such a way that they are completely retracted from the ground when not in use, see Lumberjocks link.
http://lumberjocks.com/RonStewart/blog/34189
Don't even think about locking castors being adequate, you'll be cursing the decision from day one
Regards Mick
Graham,
Mick's suggestion looks pretty neat - a good shop solution, though I am sure you can get heavy duty castors / wheels that have a foot pedal-operated affair that click either wheel or solid foot into place.
A guy on here has a tool supplier that may be able to help - I think this is the link;
http://www.tool-me-up.co.uk/castors-2615-c.asp
Just thought - I know where else I've seen them - hospital beds. They are very strong and easily foot locked / released.
HTH
Greg
Another option is to have two of the legs 20mm or so shorter than optimum and have two castors supporting this end.
Move bench in wheelbarrow mode into position and then wedge up the two castor supported legs with taper chocks.
This how I move my small bench around which is fitted with a router and has been used for lathe support at turning meet.
    9.2 KB
