I am thinking about making a base for a farmhouse style dining table. It seems i only need 3 things for this: Legs, Fixings, and "Frame" (that's what I call it... but i'm referring to the frame that the table top and legs attach to.
I've sourced some turned pine legs, so i'm sorted there.
I can sort out the fixings.
What i'm missing is the frame. I'm not sure what material to use. My first guess would be pine board (2cm thick, 10cm high) but I wonder whether this will cut the mustard.
I intend to fix the "frame" boards to the legs using pocket holes, and then use some kind of diagonal brace (also screwed into the leg). My feeling is that any pine board i get from Wickes/B&Q will be too soft, and over time i'll get wobble, which will annoy me.
Does anyone have any suggestions for the material i should be using for this frame?
