Farm Boy
Dalboy
18 Sep 2008
Canterbury United Kingdom
I was asked to post this, not sure if here under projects or in the metalworking heading. For a while now, I have been building a model of a Farm Boy hit and miss engine with thee hope of getting it running at the end.
Just a few photos of the work so far as there are a lot if I was to post all of them. This is made from bar stock except the two flywheel.
Front body shaped.JPGDSCF3063.JPGDSCF3083.JPGDSCF3095.jpghopper machining (3).jpgHopper machining (6).jpgJoining rear and front base units (3).jpgcon rod (3).jpgcon rod with bearings (1).jpg
Nice work.
Out of interest how did you approach the silver soldering?
I have found that for fiddly jobs like this the paste is really good, although how they justify the price is beyond me.
And just being nosy how do you find the lathe, guessing a Warco from the colour?
I am a big fan of big old British machines, but well aware that the Chinese ones are getting better and better.
Would be interesting to hear your views as the owner of what looks like a relatively new one.
Thank you guys no work on it today had a company to grind a stump out.
Nice work.
I have a tub of powder that I mix as needed so can make as little or as much as needed also have different grades of silver solder. I did the governor arms while the ring was still attached to a larger piece, then bored the centre hole and parted to length.
Lathe is good but have a couple of gears stripped (My fault) here are a couple of pictures of my main equipment I an using on this build
Very similar here. I have an Amadeal 25 milling machine, very similar to yours.
Wish I had gone for the three way dro. I decided to use the inbuilt one for the quill and just fitted a two way dro set up. The quill one is actually a bit awkward to read I find.
Have a Harrison 5a lathe.
And have a little Clarke 190 bandsaw, modified to run at metal cutting speeds.
You are much tidier than me :)
Thank you guys. Not a lot to report as I am doing silly little bits and making small pins. Going through the plans and double-checking what else needs making. Getting very near the end, still need to sort out the electronics to get it running, as well as make a fuel tank and base.
Not done much lately. But I have made a start on a fuel tank. Turned the main body and ends which is a cylinder at the moment need to make a filler cap and fuel cut off outlet.
Tank sitting on two blocks which will become the supports
fuel tank support (2)
The supports cut from a larger piece which had some holes luckily the hole shown is machined out
fuel tank support (3)
Here I had machined out the bulk of what was not needed ready for some shaping.
fuel tank support (9)
After machining the curved section, they are now a lot shorter but still leaving enough room for an outlet from the tank.
fuel tank support (4)
By machining them instead of using solid blocks makes for fixing to base and tank a lot easier as well as lightening the appearance of them.
A test fit of one of the supports, not sure which will look better, the foot facing in or out. Facing in would give a little more room for the outlet if I need to work on it when it is complete.
fuel tank support (7)
fuel tank support (6)
    2.1 MB
    2.1 MB
    2 MB
    2 MB
    2 MB
    2 MB
