I want to build a little extraction system for the small dusts and wastes such as from the RAS, bandsaw, router, top of saw bench, morticer etc.
I use the extractor for big stuff from t saw and planer but would like to rig up a cheap system using 32mm waste pipe and t joints for all the above and plug it into my wickes wet and dry vac.
this will be cheap but will i be happy with it? It may be up to 5m long and run along ceiling so will I be able to suck enough with vac?
