Buff pekin
My saw has stopped working , changed usual stuff , plug fuse and machine fuse , so little lost what will be the problem ? , could it the switch to saw ? . Not a electrically mined person . Any advice will be welcome . !
As above. But how old is it? Where did you buy it? Have you got the Manual? Manual has a list of things to check if it stops. Have you tried those?
Has is got an NVR (big red knob to stop it)? It could be that. Unless it's the electronics (which converts the 220V incoming into 60V DC for the motor), electrically, it's not all that complex a machine, so unless it's a wire dropped off/broken (unlikely), most likely it's "only" going to be the On/Off switch or the speed control knob. More info needed, e.g. how/when did it stop?
You're quite right EddyCurrent, it IS basically the same saw. But the Axminster Tools version has been "cheapened" in the mechanicals area so isn't now the same as the original General International/Pegas/Excalibur machine. Axi used to be the UK dealer for the original machines (and for spares, and Pegas blades) but I don't know if that's still true now that they have their own "cheapened" version. However I THINK (don't know) that with their cheapo version Axi have not changed the electrics, only the mechanicals. It sounds from the very small amount of info that the OP has given that his problem is electrical, not mechanical, so IF he needs electrical spares, such as motor brushes or new speed controller, Axi spares should be OK.It looks VERY much like an Axminster AT535SS and the manual for that can be downloaded from their web page.
As AES said, it has a speed control so there are a few things to test.
Not trying to be "smart" Spectric, but the motor on the Excalibur 21 is brushed, 60 Volts DC.Just be logical, that is all problem solving is about. First check the socket you are pluging it into is Ok, plug something else into it. Also recheck the new fuse you fitted, it may have blown again which would indicate a short in the machine. Then with a DVM check that power is at the live side of the switch, and progress through the circuit. With no NVR switch then it is much simpler to trace through, especially if you have the circuit diagram. If it is electrically like the AT535SS then you can check power is getting to the PCB, now check the voltage rating of the motor to see if it is 230Vac. If it is then you can just apply power to the motor to see if it works, if it does you need a new PCB otherwise you need to look at the motor itself. Looking at the AT535SS it uses a brushed motor so remove the brushes and also take a look at the comutator at the bottom of the brush hole, is it black and dirty looking which indicates it at least needs cleaning.
Thats why I said to check the voltage rating of the motor to see if it is 230Vac before applying any voltage to it. So we know this PCB changes the 230 Vac to 60 VDc but what method does it use to control the speed of the motor bearing in mind it only has two wires so no direct feedback? How expensive is a new PCB, might be worth just fitting one after checking that Pot is giving full range.Not trying to be "smart" Spectric, but the motor on the Excalibur 21 is brushed, 60 Volts DC.
