ELU replacement saw blade
Fastrider
New member
17 Nov 2021
RH15 0HL
I love the saw but... |ELU Model Type MH65 needs a new blade, ideally it needs to be 165 x 30 bore with enough teeth to cut laminate worktop. Anyone know where I can get a blade these days please?
Fastrider
New member
17 Nov 2021
RH15 0HL
Thank you Colin, I'll try these, just wondering though if 36T is enough to cut laminate neatly though?
JobandKnock
Amateur curmudgeon
14 Apr 2021
Lancashire
That would have been a series 40 blade which became a deWalt series 40 (there was a 48t I believe, I certainly have a few in 180 x 30mm 48t blades for a Hilti saw). Maybe worth looking on eBay for one as DW no longer seem to list thicker 165mm blades. The other alternative might be to get a Bosch or Festool blade, 160 x 20mm and get it rebored. Festool (and compatible blades for the TS55/TS55R) have a 2.2mm kerf whilst Bosch used to list 160 and 165 x 20mm blades with a 2.5/2.6mm kerf. Lastly Irwin list a 165 x 30mm 48t blade, but it is -ve rake and I don't know the kerf width
