Phil Russell
Please accept my apologies if this is the wrong area to post this question but I thought it could be the most appropriate.
My daughter's late husband had an Elu MH165 circular saw. The power cable needs replacing, an easy job, or so I thought. The electrics are no problem; getting to the connections in the handle is. Looking at the parts diagram the handle (containing the on off switch) is held together by screws. I expected that once these were removed the handle would come apart to give access to the electric connectors. But something else is holding it together. I can spring the lower grip apart but the handle remains fixed at what appears to be a c 12mm round flat plastic grommet that covers the join in the handle at the lower front. There is no obvious way to remove this other than brute force and some leverage which makes me think that is not the way.
Does anyone know how this handle comes apart to access the switch and so be able to repair the cable?
All help appreciated.
Thank you, Phil
Thank you, Phil
