Elu/Dewalt 1251
lastminute
26 Apr 2009
West Yorkshire
I now have the Elu 1251 RAS....has anyone got a manual/information for it?
It needs setting up properly to be safe.
Anyone in my proximity BD9 with one?
Thankyou in advance.
Gerry
It seems some guy called mailee has a pdf of the manual and its been passed around most of the woodworking sites ;) Not sure if its our mailee or he has a doppelganger though :D
I also have read that the Elu 1251 is the same as the Dewalt 1251, which in turn is similar to the DW 720 RAS; I've uploaded the manual to google docs in case its useful to you: Dewalt 720 RAS user manual. You can also find the pdf on Toolstop if you prefer :wink:
Have a look at the following stuff I put on the web:-
Dewalt took over Elu and the 1251 is the same other than the badging.
A scan of my DW1251 manual http://www.drosera.f2s.com/RAS/DW1251.pdf
A scan of part of the DW Powershop manual with more useful info http://www.drosera.f2s.com/RAS/DeWaltPo ... tracts.pdf
A couple of documents about rebuild/set up http://www.drosera.f2s.com/RAS/DeWaltrebuild.pdf and http://www.drosera.f2s.com/RAS/RadialArmSawAdjust.pdf
The Dewalt Powershop Manual (part included above) also gives info on the use of the various attachments - disc sander, drum sander, router brackets, moulding head, dado cutters, sabre saw, drilling - and also includes some projects. I can scan other parts of the manual if you want.
Let me know if you want any more info.
Misterfish
Thankyou Dan-K and Misterfish...I will now endeavour to 'set up' my 1251...i may need to ask the 'odd' question should I meet any problems...which I'm sure will happen!
Regards
Gerry
