mikeiomuk
New member
Good evening
I am new to the site and hoping someone may be able to help me. I have use of a elf coronet wood lathe. part way through turning a pen I stopped the lathe to reset the tool rest, when pressing the start button it failed to run. The motor hums but will not turn over, I have checked that the motor will turn with power off and that nothing is jamming the lathe. This leads me to believe that the starter unit has failed, has anyone replaced this unit on an Elf and if so what with? below is some info that I got off the starter unit.
Brook control gear, ac motor contactor, type HE-B10SS/10
No volt load starter switch ref 8121005 overload range 3.5 amps
thermal overload relay type RH B18BS/40
motor info w370 rpm 1425
v230-240 ph1 50hz
line volts 0-440 480 500max
full load amps 13 12 10
some of the above info is hard to read but I am sure it is right.
Any information would be most welcome and thanks for your time in advance.
Mike
v230-240 ph1 50hz
Mike
