electric motor?????
lugo35
9 Jan 2006
hi all. got a pillar drill ( freebie) but the motor is dodgy, will run with out belt on, but just buzzs when they are on.(turns freely by hand)
is the the capacitor? or could it be the switch. was going to wire it without the switch to see but not got around to it yet,
andy
9fingers
26 Jul 2005
Romsey, Hampshire
Remove the belts, try spinning the motor in the opposite direction from normal and then switch on. If the motor continues in the 'wrong' direction then the capacitor is almost certainly dead. Make sure that you get one of the correct value and designed for motor running ie with a voltage rating of 400-450 volts. This will ensure a suitable margin for both motor starting and motor running applications as it could be being used in either mode.
Ebay tends to be a good source of motor capacitors - search for motor run.
hth
Bob
Lons
14 Feb 2010
Northumberland
hth
Bob
Despite your current dispute with the mods (whether right or wrong), you still offer instant expert advice to a member who needs it.
Says everything in my book Book =D> =D> =D>
Bob
woodpig
17 Sep 2011
Dorset
Bob
+1
9fingers
26 Jul 2005
Romsey, Hampshire
hth
Bob
Bob
Well I am still deeply pi88ed off by the way the moderation was applied and their rejection of my argument. It has also exposed a certain degree of personal bias that I object to but life goes on.
I seem to find it difficult not to respond to calls for help..... :roll:
Bob
lugo35
9 Jan 2006
only wanted to know about my motor ,
caught in the middle of major punch up by looks of it lol.
all i can say is thankyou for help. and dont leave just coz of a disagreement, dung happens move on
anyways tried reversing but it wont have it . got it to run on slowest speed just manages it. no gutts in motor?????????
andy
Lons
14 Feb 2010
Northumberland
lugo35":1ivipcwe said:
only wanted to know about my motor , caught in the middle of major punch up by looks of it lol. andy
:lol: :lol: I think that's called collateral damage Andy
Digit
11 Nov 2007
Wales
Does it 'growl' when rotating?
Roy.
9fingers
26 Jul 2005
Romsey, Hampshire
Hi Andy,
If your motor has a definite preference for turning one way then that rather suggests that the capacitor is having an effect and so is probably OK. You could try bypassing the switch but I doubt that this is the problem.
Has the drill ever worked since you have had it? If so can you describe the circumstances around the time it went from Ok to no good.
Was there excessive load/overheating /release of smoke etc
If you want to send it to me, I can have a look but the cost of carriage might make this an un economic proposition. Have you got any other motors you could put on it? Might be easiest solution all round.
Bob
lugo35
9 Jan 2006
it was years ago, i think it was overloaded still worked for abit then stopped. i have another motor to hand will go with this i think,
thanx for the offer to have alook,
andy
