Dw1150
greshoff
23 May 2007
I have an old DW1150 Planer thicknesser recently it has developed a problem with starting. It starts but almost immediately cuts out. I have to press the red button then green button a number of times before it will run. Is this issue to do with the switch box with the start & stop buttons or something else?
Many thanks
Phil Pascoe
29 Jan 2012
Try plugging it into a different socket before you start pulling things to bits. The most minute break in the power supply will trip the NVR - my bandsaw did this for a while, until for some other reason I plugged it in to another socket - the fault was actually a loose wire in the first socket.
greshoff
23 May 2007
Tried plugging it into different sockets, same thing happens regardless of the sockets also checked the wiring of the sockets and all looks ok so it doesn't appear to be an issue with the sockets
dickm
25 Oct 2004
North of Aberdeen
Always worth trying to remove any of the demon dust from inside the switch. Compressed air if you've got it, otherwise if you can get into the switch, gentle brushing (with it all disconnected from the mains :lol: )
greshoff
23 May 2007
Tried that, it was pretty much dust free
greshoff
23 May 2007
I assume the next thing to do is try to replace the on/off switch??
greshoff
23 May 2007
Power is getting there as it starts but almost immediately cuts out
Tom K
19 Aug 2007
NW Kent
Right if its all free to turn what happens if you hold the green switch in?
greshoff
23 May 2007
Nothing until I press the red off button then the green on button again and the same thing happens - starts but cuts out. If I repeat the proceedure - pressing the green & red buttons the machine does eventually run
Tom K
19 Aug 2007
NW Kent
Can you bypass the nvr temporarily that way you can be sure its not a fault in the motor.
srp
29 Jun 2009
south
First check that all the connections are good, starting at the plug and socket (including the 'receptacles' in the socket outlet, which sometimes open up and don't grip the plug so well). Also check all the connections in the starter. If they are all ok then it's either dust or moisture inside the starter, or it could be dirty contacts. It might be possible to strip the starter down and polish the contacts with some very fine wet/dry paper. If not then you might have to buy a new starter.
I'm not sure about the DeWalt, but there may be an adjustment for the trip current in the starter which you could try increasing a little.
In any case, it would be well worth reading 9fingers post stickied at the top to give yourself some background info before you start your diagnostics, esp p14-18.
RogerM
4 Mar 2006
Devon
From a photo this looks similar to the SIP p/t. These have a micro switch where the dust shute fits when it's used in surface planer mode which occasionally get clogged with wood chips in the rubber bellows that covers the switch mechanism, and this makes the contact intermittent. On the SIP it just needs a quick brush with a stiff brush to clear the problem. Worth a try.
greshoff
23 May 2007
I replaced the main fuse to the workshop and it seems to be working ok for now. It is strange that I did not have issues with my other machinery with similar switches. Thanks for all the input & advice
