I've made a few cuts with my new table saw. Good but not perfect, which is understandable as the blade that came with it is a 24 tooth contractors blade.
So I am now fitting my Freud 60 tooth 260 mm blade. In the setting up process i have found the fence is not square to the table. It leans in to the blade.
I have been very careful in setting the blade perpendicular to the table and that is correct. The fence is marginally out as far as parallel but that is an easy adjustment.
The problem is when I slide the fence to the blade, it touches the top teeth, but there is a 1.2mm gap at table height. measured with a vernier and double checked with feeler gauges.
Obviously this will give an inaccurate cut varying on the height of the wood leaning against it.
So I need to know if any of you experts with this saw have a way of straightening the fence up?
Theres nothing in the few pages that came with it.
Ta.
Ta.
