DUST EXTRACTOR
user 19915
25 Jun 2014
H'i iv'e just started installing a dust extraction system if you can see anything iv;e done wrong or if you have any suggestions please feel free to comment > .Also on photo's coming of the dust extractor and on to my pipe work i could not find a connector bigger enough from the 150 mm flexi to the 160 mm pipe ?? sorry i put the wrong size earlier
    190.3 KB
    152.6 KB
    169.5 KB
No haven;t finished yet and in photo no 2 iv'e got to connect up and do another short run .Does it make any difference if on photo 2 i change one of the drop offs to face the other way ??
mock
hi mock looking at photo 2 you need to turn the drops the other way for better airflow and you will need blast gates on each drop and after each drop as well ian
Why after? (not being thick... I hope)
Agree, the 'y' sections need to be the other way.
the reason for blast gates on every junction and after every junction means that you can focus the full power of your extractor to the machine your using . The 90 degree bend at the bottom is ok but i think 2no 45 degree bends and short length of pipe between would make the top work better ian
Thank's Ian can you send me the link on the axys site you found the connector :roll: :roll:
mock sorry mate not that good on the pc the part no is 900063 showing in stock £6,25 but the postage is a fiver thereabouts unless you spend £50 !
mock i must be getting old just noticed the bottom y junction that would be better on the horizontal section of pipe and again turned the other way sorry mate ian
Sorry i put the wrong size connector down earlier sorry my flexi 150 and the soil pipe 160 :oops: :oops: and what way should the y piece be :oops: :oops:
fit the y as the letter looks with the single end pointing to the extractor that gives a better airflow just been taking a look for a connector cant find one on axy tried felder no luck maybe if you want to try and make something up ?
A;S you can see in the photo i have managed to attach the flexi to the soil pie but only just and a large jubilee only time will tell :lol:
dzj":24hqzqv3 said:
If possible avoid 90 deg sections.
+1
Two 45 deg bends would be better for the air flow.
My gas engineer tried explaining bends and their effects on air flow when he did a boiler for me. It was a 'glass eye' moment, but that bit stuck.
Are you bothering with the static electricity issue?
So if i cut a bend in half and join back up with a Drainage Coupler with Central Stop for Joining Sections would that be ok ??
And regarding the static electricity issue i have seen a video showing how to do it would you recommend ??
Just had a little look i can't cut the bend in half to add a coupler and the bends are 87 degree on a 6 inch pipe ??
hi mate if your stuck do you want me to take a look ? if youve still got my no give me a bell , ian
Personally I would avoid 90 deg bends completely. I would use a 45 on the vertical, a 45 on the horizontal and a short piece joining the two together. It will be a more gentle control of the airflow rather than the sudden bend of the 90 deg bend.
I know it's a different application, but with my flue issue some years back the gas boys tried a few combinations to get it working properly.
All the trouble was due to neighbours building an extension too close :evil: So when we had the boiler replaced the old flue location was no good. So they tried a 90 bend to get it vertical, that didn't work. Then it was the two 45 bends , that worked a lot better but still wasn't perfect. In the end they used a "twin flue" and everything was bang on. Bloody expensive. But the information stuck with me.
Regarding the static I really don't know, I was just wondering if you were doing anything about it. It seemed to be quite a concern with some people from what I've read when researching dust extraction.
I understand how it works, but whether or not it really is a big issue from the point of explosion and fire in a hobby/home workshop I'm not sure. The commercial shops I've been in use steel ducting, I guess rendering the issue nil.
In some literature I read, one guy makes out it couldn't happen due to the wood moisture content rendering it too wet for an explosion. He didn't say anything about man made materials, mdf, etc, which I guess must be really dry.
Besides the fire/explosion issue we all know a static shock can make you jump. I wonder if this should occur could it lead into another kind of accident when using one of the power tools.
I really don't believe there will be enough static electricity created to cause an electrocution problem, if that should become a concern, but there's a lot of people doing different things to try and control the static issue.
My only personal experience with static and plastic ducts/pipework, was with me crimping some lugs onto some cable for a site engineer at a chemical company in Newport, as a favour.
I obviously asked what it was for and he told me. Their situation is quite different though due to the nature of the materials they are pumping/moving through the system.
Other than some of the points raised what you're doing is looking good. Good luck :D
