Just taken delivery of a new dust extractor which unfortunately doesn’t work !
As we have not got to the bottom of why or who’s to blame I won’t throw the supplier under the bus as yet although the pictures may give the game away for those in the know
The extractor has a 3kW (4hp) motor which is running (or rather not !) on a 230V single phase supply through a 16A Type-C circuit breaker.
I am no electrician but as I understand it the motor is in fact 3-phase but the start and run capacitors in the junction box mounted on the motor itself allow it to be run on single phase.
And so the symptoms.
The motor takes what I feel is far too long to come up to speed and before it reaches full speed the motor protection breaker in the control box trips out and cuts the power. This happens 99 times out of 100 although once or twice it has managed to stay running continuously without a trip (this fact may be significant ?)
The motor protection is set at 14A which appears to be correct given 3kW at 230V.As a test I tried adjusting it up to approx. 18A but then the 16A circuit breaker in the fuse box tripped instead.
I have measured the current being pulled by the motor on startup and this is initially at around 45A dropping to approx. 25A when it trips out.
I havn’t yet tested whether the capacitors are faulty as that would entail cutting the wires and I don’t want to do this until the supplies gives me the go ahead to do this.
Can anyone help or suggest what the fault could be ? Is there any likelihood the problem can be the fact that I only have a 16A supply ? Should it have been 20A for instance.
I should add that I am located in Norway (expat Brit) and logistically this is a nightmare for all involved as simply returning the whole machine is going to be extremely difficult, and expensive.
I am becoming increasingly desperate and so far the supplier has been very sympathetic but of little practical help
Lot of pictures attached
Mark
Mark
