ScottGoddard
So I have been waiting to do this for a number of months now! haven't used it will cutting but the suction noise through the table saw is impressive!
I have moved the extractor in the rafters (to create space), which of course meant putting in ducting! So I have done one side, I have out 150mm all over the ceiling, down the wall and to the machine only leaving about 30cm of flex. I haven't taped the down pipe as I will be putting in two Y bends later on for the planner, floor sweep.
I haven't yet added the remote switch as i need to work out how to cable tie it on! there is no access around the back. Will probably loosen the box off the extractor.
