Hi all,
I know this has been asked lots of times before and I have read through as many posts as I can find in the search but I don't quite fit the typical profile of those asking as I'm female and of slim build so have quite a small face.
There seems to be so many products out there that the choice is very confusing.
I'm looking for the best options for both dust extration and a dust mask.
Starting with the dusk mask:
Currently I've been using a Venitex FFP2 valved disposable dust mask which seems ok but I'm having problems with getting a good seal - one side near the nose always seems to have a gap and the mask also makes my safety glasses steam up which isn't great for safety!
I've read about a few options - Air race, 3M 6000 / 7500, and other similar products and the powered options such as the Powercap and Airshield Pro.
As to the powered respirators, the cost is high so would you go for spending a bit more on a good dust extrator and buy a non-powered dust mask as back up protection?
I can't really afford both and I don't think my current usage would justify it.
We're looking at a couple of hours in the evening and a few hours at the weekend currently. If things work out then this may change in the future but I could upgrade a face mask if necessary.
I kind of feel it woud be better to try and eliminate as much of the dust as possible at source rather than rely solely on a mask but I realise that both would be better than 1.
In terms of dust masks I'm wondering which might be best suited to a woman of smallish build? I'm 5ft 4" and I have a small head. I don't wear glasses and obviusly don't have the beard problem
For dust extraction options - I am currently using:
a Multico 14" bandsaw which has a dust extraction port at the bottom wheel (though I wonder if this would be much use - wouldn't it be better to suck dust away under the table more at source?)
Seig Micro mill which does create quite fine dust
Small Proxxon table saw which has a port for a standard hoover
Small disk sander.
I may get a router if sales justify the purchase.
A little bit of wood turning on a Seig C0 baby lathe
Apart from the wood turning with various pen blanks I'm mostly cutting Jelutong which I don't think is toxic but for what I'm doing does produce quite a fine dust.
It is more dust extraction that is the issue rather than chips.
A friend recently got the entry level trade Axminster dust extractor (I think it's about £120) for his miniature wood turning and I was wondering if this is a bit basic for my needs or if something like that, or the step up would be suitable.
He reckons it removes 100% of the dust but he's just using a Unimat classic so it's no bigger than an A4 sheet of paper!
I'm also using smallish tools for my miniature work rather than standard power tools but for the bandsaw especially it may need a bit more grunt.
I also don't want a situation where I extract the dust and the lack of filtration ends up putting even finer dust into the atmosphere.
With xmas coming up I could look to get something for then.
Sorry if the post is a bit long winded!
Thanks for any advice,
Jennifer,
Small disk sander.
Jennifer,
