A long running Tuit of the extractor system was to add a final section to the crown guard on the tablesaw. I finally got round to it this weekend. As it didn't involve too much lifting or twisting, I decided it'd be OK given the back injury.
I'd managed to pick up a few bits and pieces as they removed the "clean rooms" from work. (I work for an electronics company and we maintain certain rooms at specific levels of comtaminents in the air - e.g dust). Anyway, I found one was a perfect adaptor from the TS crown guard, to 80mm pipe.
click on image for larger view
With this installed, I was able to fit some 80mm pipe to it
I made a 80mm - 100mm adaptor by cutting a "wedge" out of some 110mm pipe, heating it on the gas hob, and folding it to size, it looks a bit heath-robinson, but works fine.
I then used a "U" clip on the roof, to hold the pipes up out of the way. You can see here a join from 80mm to 100mm using the adaptor above, just where it goes through the clip. You can see I've also added a blast gate, and a "Y" section. I need to couple it into the original installation, and the flexible pipe has already been disconnected.
You can see here the "Y" section installed, and the two pipes that split from it.
I still have an unterminated end which doesn't have a blast gate - I've taken to plugging it instead of using a blast gate...
Which is nothing more than an piece of tube, with some wood through it to stop it disappearing.... (it's a perfect fit)
From several car-boots, and a couple of clearouts at work, I seem to have aquired a good range of measuring equipment.
I'd never come across these before, it's a quick release vice - does it have a "proper" name does anyone know?
One of the things I got is an engineering square, I decided it's not good in a drawer - I need it where I can grab it quickly.
So I made a little holder. Might not be much, but each little item indicates I'm on the road to recovery
Adam
