dual fuel radiators
MattMoore
6 Nov 2004
Hertfordshire
hi all,
just about to fit a duel fuel rad for a customer,
just wodnering what spec cable i need to supply power to the thing?
cheers all
What is the wattage of the electric element :?: as this will determine size.
If it's a towel warmer then these are usually no more than 200W but can go upto around 1.0kw. As they all need to be wired into a fused spur which will be part of your ring main, then 2.5mm2 to the spur.
Jason
how does part p come into play with these? theres an electreician coming in to do the final connections, but i've laid it, is that ok within the regs?
