Drywall under stairs
Designer1
4 Mar 2021
York
Hi,
I'm interested in putting some under stairs storage under these cupboards but am a bit cautious of what is lurking behind the drywall. As far as I know it's just stud wall with a small frame at the end on the inside of the cupboard to make the small flat section. Can anyone confirm this or has anyone had previous experience of a similar situation? I have attached pictures of the area I am looking to do and the picture of the stud wall is one from Google, I am assuming this is what it is like. If anyone has had experience with this it would be greatly appreciated.
Thanks,
Designer1
I would assume it to be as you said. They are often squared off like that because it’s difficult to finish with drywall, plaster and skirting due the the lack of head room.
Unless it’s hiding a secret portal to an alternate universe.
If it’s the latter it will at least provide lots of additional storage space.
It should be like the pik.... cut out the plasterboard on the inside and take a look :) if you cut a neat hole you can always put it back in on battens
Yes I never thought of that, much better option than going head first with the drywall saw
