Drilling very wet, very hard wood
LJM
27 Aug 2012
Cheshire
I’m working on a project that requires the drilling of very wet greenheart; it’s underwater, so there is no way around the fact that it’s wet.
Holes need to be 26mm diameter, c. 300mm deep. The drill is hydraulic. Auger bits have been tried; they cut nicely through the fist 30mm or so, then simply stop cutting in to the timber. Standard twist drills don’t fair much better.
Keeping in mind that these are being drilled free-hand, mid-water, and need to be accurate (so that the fabricated fixtures fit), I’m looking for possible solutions to this problem... any thoughts?
Argus
21 Oct 2002
Accurate pilot hole first, then successively thicker drills to the required diameter?
...................awful lotta work. What's it for?
LJM
27 Aug 2012
Cheshire
Repairs to a lock gate. Oh, I forgot to mention; there is no visibility, so working blind. One of several reasons that centering the drill is challenging and so a pilot hole could prove problematic.
RobinBHM
17 Sep 2011
Wst Sussex
I wouldve thought drilling holes in a lockgate...kind of defeats the purpose :)
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
Can you screw a block with a hole in it to act as a drill guide for at least the first part of the hole? Is there a way you can get a clamp on feed for the drill? Something like a magnetic drill that you can apply more pressure on the bit. Hydraulic underwater Magnetic core drill | Ultimate Tools Something like this. Even if you have to clamp a steel plate to the lock and attach the mag drill to it.
converse
8 Apr 2021
Lincolnshire
Make a jig and coach bolt it to the face? Water jet cutter? Drain a section of canal and take the gate off? Trench Piles around the gate and pump it out? Abrasive drill head with water lubrication?
Cabinetman
5 Jan 2017
lincolnshire Wolds
I think the only bit that will do it is the auger bit, it’s stopped digging because of a let up in pressure, would it be possible to use a ratchet strap through a pair of bolted on brackets (one each side of the hole) and over the top of the drill to maintain the pressure? Ian
LJM
27 Aug 2012
Cheshire
No, because there’s limited access to the point that needs drilling and the client won’t shell out!
LJM
27 Aug 2012
Cheshire
No; theses holes are for coach bolts, which simply won’t drive in otherwise. But also there is the access issue
LJM
27 Aug 2012
Cheshire
There was no let up in pressure, believe me! 40 minutes with all my weight behind , and no progressit; the first 30mm didn’t need anything like that.
converse
8 Apr 2021
Lincolnshire
Some jobs can't be done at a price that the customer is prepared to pay. If you really are limited to someone in a wetsuit hanging off the lock gate, I'd try a few different types of drill bit with your existing set up (including metal bits), then I'd probably suggest a much bigger budget was going to be needed.
smackie
1 Oct 2020
Kendal
Oof. I don’t think I’ve ever seen the Canals and Rivers Trust (or British Waterways as was) ever attempt to do this underwater. There’s usually a deep groove in the stone lock chamber upstream and downstream of the gates to allow blanking timbers to be dropped in as a temporary dam that allows the lock to be drained for service.
That allows the usual gear to be used to service the gates.
LJM
27 Aug 2012
Cheshire
Well it’s down to the client; we can’t lift the gates out (it would render the dock inoperable ), and the job is on a day rate, not a fixed price... so ultimately, do I really want the client to splash out on a piece of equipment that massively speeds up the job??
LJM
27 Aug 2012
Cheshire
Ive done it several times for CRT! Though they’re not the client in this instance.
They’re called stop-logs and stop-log channels; a big crane is required to lift them in and out, which the client is averse to. But they also close the lock.
Further to that is that these gates are on a tidal river, and the inner dock doesn’t run dry; massive pumps would also be needed to keep the gates dry
smackie
1 Oct 2020
Kendal
Ah. Okay. Yeah, that gets pretty complicated. Sorry - wasn’t trying to teach you to suck eggs, just trying to figure out why the chamber couldn’t be drained...
All I can think of is the same as @Argus - something like a 8mm pilot hole to allow the centering bit of the augur to get continual purchase on something and to stop the augur just skidding on the face?
Good luck!
Inspector
18 Jun 2006
Guess you are left with training shipworms to do the job. They will do just about anything for a nice piece of Mahogany at the end of the workday. ;)
