Drilling on the Lathe
UKTony
12 Nov 2004
Stevenage
Making lots of progess, want to attempt a couple of bud vases since i have a few inserts, whats the best "bit" for drilling, Auger, Forstner or flat drill bit and is there a technique, my books seem to have limited info on drilling, i have all the tools i need i think
T
Tony,
For bud vases I use an ordinary twist drill - works fine for me (up to about 12mm diameter).
For larger, shallow holes I use a Forstner bit (remember to use a slow speed!).
For deeper holes I use a flat bit (up to 32mm dia), again slow down, and be prepared for some fierce vibration!
I don't possess any auger drills, but I suppose that they would work well too.
tony i have used the flat bits its slow slow stop stop slow the bit can get hot and i mean hot :) so take your time or it will jam .
frank
When drilling wood on my metal working lathe (2MT in the tailstock) I prefer to use a Forstner bit if possibe. A twist drill will work well too.
I doubt an auger bit would work very well inasmuch the screw thread on the pilot will want to pull the tailstock forward and hence risk loosening the tapered mandrel on a chuck.
