mike s
hi
how do i drill a hole in high speed steel?
will carbide drill bits cut it?
thanks
thanks
NetBlindPaul":1kveqbdx said:You can soften HSS with heat treatment, you should not drill ferrous materials with diamond as diamond is carbon, ferrous materials contain carbon and they react together.
What ou may need is a Stellite (TM) drill bit.
What are you trying to drill, what size and for what purpose there maybe other options.
Stellite drills are what I use to drill metal cutting hand files.
