Drilling cast iron soil pipe
Marineboy
11 Mar 2016
Northumberland
I’m redoing the bathroom and have decided the most elegant route for the waste is straight through the wall and into the adjacent soil pipe. I have the plastic boss which fits into a 57mm hole in the pipe and looks very neat.
However, the challenge is drilling the hole. I’ve watched a YouTube vid and saw a bloke using a Starrett bi metal hole saw to do just what I want, so I bought the very same tool. Tried this pm to cut the hole. Drilling the central hole with the bit was ok but slow, but when it came to the actual hole... I was on ages and have made barely a mark. Am I doing something wrong, or is there a better tool out there?
kevinlightfoot
11 Aug 2016
Mansfield
Sam is right cast iron should cut easily,is the hole saw a good make or a cheap Chinese cheese metal one.Starret are usually good tools perhaps you have a duff one.
Marineboy
11 Mar 2016
Northumberland
It’s a Starrett, not noted for producing rubbish. And although I’ve been on ages with it the the teeth still feel sharp.
sunnybob
wysiwyg
11 Oct 2014
cyprus
Speed is important. most hand power drill speeds are too slow, or too fast, for hole cutters.
try 2nd speed, but keep the trigger half compressed.
Trevanion
Greatest Of All Time
29 Jul 2018
Pembrokeshire
As already said, old cast iron should cut fairly easily... Unless it's more modern ductile iron piping which can be a pain. Slow speed, heavy pressure and a bit of oil helps.
If all else fails, drill small holes around the diameter of what you want and punch it in with a hammer.
Marineboy
11 Mar 2016
Northumberland
Thanks Trevanion, there seems to be a consensus that cast iron cuts easily so I’m wondering if in fact it might be this ductile iron stuff. The bit I’ve cut looks bright and silvery - can this be a clue as to the metal?
Trevanion
29 Jul 2018
Pembrokeshire
Cast iron tends to be less shiny and darker from experience and the chips created are more like black dust and it's very dirty.
Ductile Iron as far as I'm aware creates a chip like steel would but I've never actually worked with enough of the stuff to give any real advice.
Trevanion
29 Jul 2018
Pembrokeshire
SammyQ":2squay7y said:
Just a casual thought: the drill rotation is clockwise as you view it? You haven't - by accident - got it in reverse?
Sam
I unknowingly had a left-handed drill bit once :lol: Took me a good while to figure out why it wasn't cutting at all.
Marineboy
11 Mar 2016
Northumberland
Sam - I’m certainly capable of that kind of idiocy but not in this case. I’ll have another go tomorrow, keeping it slow, putting oil on it, and applying as much pressure as I can, which is not easy 6 foot up a ladder.
Racers
22 Apr 2005
I though that left handed bits where for filling in holes...
julianf
10 Nov 2017
devon
As mentioned above, cut it with (probably) the slowest setting on your drill.
For example, my mains drill has no speed control and I wouldn't even bother trying with it - I'd buy/borrow a slow speed battery drill and do it with that.
MusicMan
1 Jul 2015
Warwick
There are many variations of cast iron. I agree the type used for machinery beds (grey cast iron) usually machines well. Some
cuts easily but can still have a very hard skin at the surface. White cast iron is extremely hard all through.
A simple test is to see if you can file it fairly easily or whether the file just skates off.
Lons
14 Feb 2010
Northumberland
Just a thought.
If you do manage to drill it be very careful the cut piece doesn't drop into the soil stack as it will lodge itself in the first bend and over time cause a blockage which will be very expensive to clear.
Not easy to stop but there are ways.
First check if there is a bolt on access panel below where you're cutting in which case it's easy to block it there and catch the cut out.
If the open outlet of the stack is straight above gutter height then it can be possible to lower as securely tied circle of wood ideally with a magnet attached to below where you're cutting and pull it up afterwards or alternatively stop just short of drilling right through, secure the piece you're cutting with bent stiff wire through the centre hole and finish the cut with small drill holes before knocking it out.
As an aside, regularly check the chuck on your drill is tight. My brother was drilling through a stack on one of our jobs, the hole cutter came out of the chuck as it broke through( plastic pipe ) and dropped a metre down and round a bend which was inaccessible under a concrete garage floor. I hell of a lot of verbal abuse followed and we lost 2 hours fishing it out with a very strong magnet as it was heavy. The alternative was unthinkable and I never let him near a stack again. :roll:
SammyQ
12 Apr 2005
A wee house on a hill
Thanks Musicman, I was unaware of different grades of cast iron.
Marineboy, another casual (read: slow and dopey) thought: if Musicman is right, whole different kettle of fish compared to the cast I'm used to, but...in model engineering, it is not unusual to encounter a harder 'crust' on castings. This has to be aggressively machined away to reach the softer 'cast proper' underneath.
So...if you managed a centre hole successfully, what say you to drilling a circle of shallow holes with that same drill, getting through the 'skin', then retrying with your hole saw?
Good luck. Sam.
Marineboy
11 Mar 2016
Northumberland
Thanks for all those replies fellas, I’ve had a long hard think and I’m throwing in the towel. I’m still not sure I can actually drill through the sodding thing and even if I do the nightmare scenarios described by Lons are truly terrifying. I’m going to get some longer pipe and connect via a tee to the shower waste - it means routing the waste round the soil pipe with some elbows which is not very pretty but it’s at the back of the house and we can’t really see it. Importantly, resident chief of design has no objection to this workaround.
Lons
14 Feb 2010
Northumberland
I didn't mean to put you off Marineboy just trying tell you to make provisions to prevent problems. If if was my house I'd be drilling the stack.
sunnybob
wysiwyg
11 Oct 2014
cyprus
If its any easier, theres no need for 4" pipe once youve gone higher than the toilet pan. Its simple to fit a reducer and run any sink waste in smaller diameter, 3 or even 2" all the way up to the roof vent.
