Quantcast
Drilling bathroom tiles.
artie
Sawdust manufacturer.
12 Jan 2015
Norn Iron
SWMBO has produced a blind for the bathroom window.
I have never drilled tiles before and am hesitant to try.
Any tips or alternatives welcome.
Noel
Moderator
Staff member
Moderator
7 Aug 2003
Drilling tiles shouldn’t be a problem Artie.
Nip down to the hardware shop, buy a tile/glass bIt, 6mm is usually best (and often only size you’ll get locally). Stick a bit of masking tape on the tile and mark your place to drill. Slowly drill through tile and stop, then go with a masonry bit. Tap in a plug but make sure it settles behind the tile, otherwise there’s a chance of tile cracking.
Once done you’ll realise it’s not difficult.
Sheffield Tony
Ghost of the disenchanted
2 Aug 2012
Bedfordshire
I have a box of drill bits from Bosch which claim to drill anything. They are basically like a masonry drill but actually almost sharp. They go through tiles without much bother, even in a small cordless drill.
Tris
What am I doing here?
28 Nov 2018
Moreton in marsh
Stick a piece of masking tape on where the hole is to go before you start with the tile drill to stop the point wandering
Rorton
22 Mar 2019
Stoke on Trent
Don’t put the hammer action on the drill till through the tile either
for me, as above, masking tape with a masonry drill bit, drill though the tile without the drill on hammer, then when through the tile and into plaster/brick, turn hammer on and finish the hole.
DBT85
19 Dec 2015
Pershore, Worcester
Same as Rorton. normal masonry bit, masking tape to stop it dancing around. Start it slow to get through the glaze neatly.
Cut the flange off the rawl plug and push it through the tile into the wall behind.
Doug B
Shy Tot
6 Aug 2008
@dougsworkshop
I use these for standard tiles
& these for porcelain, marble etc,
xy mosian
21 Feb 2009
West Yorkshire
If it is a tile with a softish core covered with glaze, I normally chip away a small area of the glaze with a hard pointed screw. Very gentle hammer taps used of coarse. Chip an area larger than the intended hole, change to a suitable masonary bit and, without hammer action, away you go. It came from a need to drill a tile before glass drills were widely available.
HTH.
xy.
Nigel Burden
23 Oct 2018
Dorset
I have a tile bit, with it in the drill chuck I just turn the chuck by hand until I've chipped the glaze then the tile drills easily, but take it slowly.
Nigel.
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
Word to the wise - protect your eyes and lungs from the dust from ceramic tiles - the glaze dust is to all intents and purposes ground glass DAMHIKT :cool:
novocaine
21 Jul 2014
Warrington
I got a set of these and have never looked back.
Ceramic needs a steeper rake.
DaveG
7 Oct 2020
Wales
Masking tape or even sellotape to stop the bit slipping and a spade type tile drill Argue ..:: job jobbed!
Rorschach
Agent Provocateur
6 Jan 2016
Devon
I use a Lidl tile drill guide with diamond bits, works great and no chance of the bit wandering. I bought more 6mm diamond bits from China as that is my most used size and gets worn out after a while.
Looks like this, was about £7 for the set I think, well worth it.
AdamM
New member
27 Sep 2020
Hawthorn, Alton, UK
Another small tip, get a used envelope and masking tape. Carefully remove the envelope flap. Stick the envelope below the drill point to catch 90%+ of the drill waste.
britinfrance
17 Mar 2014
Indre, France
Had a similar problem in an ex-council house - The tiles (as per the advice here) but under the tiles was a reinforced concrete lintel and my masonry bit - 3 of them - ended up bent and useless. I had recently bought a SDS drill and albeit heavy 8kg, it went through the lintel like butter, everything plugged up -sorted! :)
