Drill press jig completed
Chris Knight
14 Jan 2004
SE London - NW Kent
CYC,
Nice looking drill press table. I see you made the table wrap around the column so the fence can slide back as far as the column - very sensible! I did not do this with my own set-up and the usabale area of the table surface is reduced considerably.
CYC
23 Jul 2003
Kildare, Ireland
Yes Chris, this is critical to maximise the working space on the table. I must give credits to Neil (the irish one) who paved the way and made me not forget about this important detail. Thanks again Neil :wink:
You will see that I had to nodge the table on the right of the column as well as use 2 layers of 18mm plywood on the foot (the base that is bolted to drill press' steel base) to allow the height adjustment swivel to swing free!
