draws.
I'm guilty, I use an iPad to make my contributions, and the thing keeps anticipating what I'm writing and completes the words. Drawers usual self populates as draws. Sometimes I just can't face trying to change all the auto-inserted words, other times my schooling which was at a modern comp, where it was a about getting the ideas down and sod it to spelling and grammar kicks in and let's me down woefully. I've Imprived a lot over the years thanks to spell check.
phil.p":3tz60hai said:
Why do people refer to drawers as draws? Is it a regional thing? I don't recall drawers being called draws anywhere other than here. :?
Phil,
I think it is because they either cannot spell, (Like my nephew, who was taught via the 'phonetic' spelling system in the nineteen-seventies, and has a few 'blind spots') or they just can't be bothered, when they can use text speak. Eg. M8 and cu l8er. I can't see the problem, as long as they can be understood. Communication is the name of the game.
Winter draws on! :D
In my experience, the problem is that the set of people who can understand stuff like text speak or homophonous mis-spellings is markedly smaller than the set of people who can understand 'proper' English. For example, my partner is Italian - she speaks pretty much fluent English, can easily communicate with people in the street and only really has a problem with a few esoteric idioms... but still needs to ask me to double-check what people mean when people mis-spell stuff or use similar-but-not-correct words.
On a related note, another thing that at first glance looks like a mis-spelling which I'd only encountered here for a long time - but have seen elsewhere enough to think there's probably something behind it rather than just a typo - is "off." - e.g. when someone writes a BoM or something with phrases like:
50mm M6 hex-head bolts - 6 off.
or
4 off. 2440x1220mm 18mm ply
- Obviously 'of' would fit perfectly well in there and retain the same meaning, but I get the impression it's not that. Or are loads of people really adding an extra 'f' to 'of' for no reason?
Jake;
I always knew it as 'off'; eg., 6 "off the list" or the spec.
But I never really had it explained; just accepted it was 'off' :) .
Benchwayze":zldzraes said:
Jake;
same here, no idea why.
I don't know about regional, In my grandad's day, drawers referred to a ladies underwear as well!
Rodders
marcros":1sc623th said:
Benchwayze":1sc623th said:
Jake;
The most obvious example is when a hand crafted, unique item is described as a "one off".
You wouldn't (I hope) call it a "one of".
I don't know the derivation (and can't be bothered to research it).
BugBear
Hi
Language, and its associated record, writing, will always evolve. However I believe that evolution is no longer driven by the need for accuracy but by fashion / marketing.
As a forum dedicated to a discipline which errs towards accuracy and tradition I feel we should encourage the use of correct terminology and grammar, not at the expense of alienating members but perhaps with the aim to promote the use of a 'common language'.
Regards Mick
phil.p":2kdtt2y2 said:
"4 of 2240 x 1220 x 18MM" What's the problem - I've only taken the "f" off of "off". :)
no good. Traditionally x number off rather than of. It is bad grammar to say of. It sounds as bad as F-of all in the pronunciation old lad. :D :D :D :D
It's just laziness, nowadays every thing is speed, even writing, (Do people still write?) I have to admit I hate text speak and have trouble understanding it! I text like I type with the correct words but I am an old git who still uses imperial measurements too. :lol:
I can't believe none of you knowledgeable gentlemen know what "off" means on a list of materials :shock:
Off = Order F****** Fast :lol:
And it drives me nuts when I hear offen the 'bus. ; I also dislike the missing apostrophe, from 'bus; as short for omnibus! :lol: burrit ain't the end of t'world! (hammer)
I still like to use 'phone with the apostrophe, hate the oozing import 'gotten'.
