Dowel size advice
roadrunner45
21 Feb 2021
Wimborne
Hello All,
I am after some advice regarding the correct dowel size to use in a project, the help I am after is -
What diameter to use (6 , 8 or 10)?
What dowel length would I need , which I imagine is determined by thickness of wood?
Best place to buy wood dowels from , as when I visit screwfix, wickes etc they seem to have limited options?
Thanks for your help.
Jacob
7 Jul 2010
Derbyshire
Hello All,
Loads on ebay dowelling | eBay
What are you making?
Austin Branson
18 Jan 2013
Ticheville, Normandy
Hello,
I very rarely use dowels, but a rule of thumb for a traditional mortice and tenon is a third. The tenon is one third the thickness of the timber. As a starter for ten, I would run with a similar approach to dowels. I am assuming that you are doing edge to face joints. If you are pegging joints, I drill the holes a distance of at least one and a half times the diameter of the peg from the edge of the timber. I’m sure there are plenty of better experienced folks out there who can give you better advice. Best wishes.
John Hall
19 Jan 2022
Manchester
Lots more detail regarding what your making would be really useful…it’s hard to advise without knowing what it’s for.
roadrunner45
21 Feb 2021
Wimborne
As above a bit more info will help people guide you in the right direction :)
Hello , the project i am working on is a shoe rack from plywood , please see image below -
I have cut all the wood and was going to assemble with dowels , so there is no visible fixings.
Thank you.
Jacob
7 Jul 2010
Derbyshire
MARK.B.
4 Jul 2012
East Yorkshire
As Jacob says glue and screw from the back, it will be a lot less faffing around than trying to assemble with dowels and removes the risk of getting your holes misaligned which is never a good thing ;);):)
roadrunner45
21 Feb 2021
Wimborne
Thanks for your reply, I will construct with glue and screws , what would you recommend for the finish, is there a clear lacquer for plywood?
Jacob
7 Jul 2010
Derbyshire
Lots of options. I'd go for Osmo oil, mainly because I've used it for floors and other things and it seems easy to use and very hard wearing.
MARK.B.
4 Jul 2012
East Yorkshire
There are quite a few as Jacob say's , I made a shoe rack for my daughter and her family and used a cheap bargain brand flooring varnish , its tough as old boots if you will forgive the pun :) Almost 5 years old now and still looks pretty good.
